Not receiving text message in ultra power-saving mode
RLamont21
Everytime I go to ultra power-saving mode on the Galaxy S7 Edge, I no longer receive my text messages. I started having this problem with a couple of days ago. Did I do something wrong on my phone? How do I fix this because I tried going to my phone settings I don't have a clue what's the problem.
Ultra power saving mode severely restricts what the phone can do.
(See pg 271 of the Sprint s7 Edge user manual)
https://docs.google.com/viewer?url=...240/SPT_SM-G935P_GS7-Edge_EN_UG_MM_6.1_R3.pdf
When the screen is off,data gets turned off,as does WI-FI & Bluetooth.
I'm guessing this is why you're missing text messages.
I don't know if the messages will appear one the screen is on,or,if you return to normal power mode.
Also,I'm not sure if you can exclude SMS/MMS/phone calls from being affected by ultra power savings mode.
Hopefully,some others will chime-in................
The thing is it was getting text messages while on ultra power-saving mode since I had the phone. It stopped doing it a couple days ago.
The only way to use messaging with Ultra Saver mode is if the screen is already on and/or your doing something with it. Once it turns off all data, wifi too is turned off.
