Hi
I've got a Galaxy Note 10.1.
A few weeks ago it came up with a message that my SD card was corrupted. Checked and sure enough it had bit the dust.
Bought a new SD card (micro sdhc) transferred my music files to it, tested it on my pc and the files would play.
Stuck it in my Note and it sees the SD card but it says there's no files on it?
Took it out and checked on my PC again and all worked fine.
I'm using the exFat format.
Cheers if anybody has a fix.
