Help NOTE 3 N900P SPRINT LOST APN,IMEI after Factory Reset! Help S.O.S
:):(Hi Am new in the Forum & First of all thanks to all of you for helping the forum and people. I'm having difficulties and I cant seem to find the way to fix this(its been 3 weeks)
My problem is the following: I have a Samsung Galaxy Note 3 details:
software version: N900PVPUBMI3
hardware version N900P.00
Status: network: Digital roaming
mobile network type CDMA-AxRTT
Android 4.4.2
KERNEL:3.4.0-951486dpi@SWDD5712#1
A friend bought me this phone and called my carrier METROPCS and made them set up the phone so I could use it. they asked him for imei and sim number. He was able to use the phone and 4GLTE(he was doing this to verify it was unlocked) later on he gave me the phone and I had to do the same procedure he did but first I did a factory data reset.
After the reset I wasn't able to set it up again.
I've noticed that APN SETTINGS has disappeared from the menu, cant search for networks, when I load IMEI it no longer shows the imei but it shows MEID B0000000 and besides all of this I have a message that says SIM CARD INVALID.(but the sim card works perfectly on my other phone)
I will all my life appreciate if you help me with this matter please!
PS. phone is rooted.
I'm thinking it was flashed and lost the flash? Would you please tell me how to fix it :( ?
