Note 4 not turning on
Boax
My note 4 has not been able to turn on. It has been just staying on the note 4 sign and never loading past that. Not only that if I don't freeze the phone it won't even load the note 4 sign. I have done nothing to my phone and I tried factory resetting my phone but it hasn't changed. It is not the battery as I have just bought another one and still no difference
Can you get into recovery mode (press Power Button, Home Button and Volume Up Button at the same time)? If you can do this then I would try to delete the cache directory to see if this helps.
Regards,
Eric.
