So i tried installing CM Remix Rom for my Samsung Galaxy Note 4 SM-N910F running Android 5.0. And i keep getting this error when i try to install the file via TWRP (this package is for device trltexx, trltedt; this device is trlte) What can be the problem?
Make double or triple sure that the CM ROM you're trying to flash is specifically for the SM-N910F. If it's for any other version of the Note 4, it may very well brick your device... if it installs at all. These ROMs are very device-specific.
I just relised i had an old Version of TWRP and then i went to thier site and checked that out and it says that the TWRP for my Qualcom isnt the right one for this custom recovery
If any moderator could close this topic id appriciate it. I was using a false version of my TWRP and i changed my CM remix to CM12 nightly Android 5.1.1 instead. I did what you said The_Chief and that was also the problem the Rom i was trying to install was for 910T or C so :/
