Help Note 4, Tasker, wifi
Need information on what you are trying to do. The link you posted doesn;t help. Here's a profile I use all the time ...
Profile: tlaOfficeFar
State: Not Wifi Connected [ SSID:xxxxxx/yyyyyy MAC:* IP:* ]
Enter: tlaOfficeFarEnter
A1: Wait [ MS:0 Seconds:0 Minutes:1 Hours:0 Days:0 ]
A2: Variable Split [ Name:%WIFII Splitter: Delete Base:Off ]
A3: Perform Task [ Name:tlaWiFiOff Priority:5 Parameter 1 (%par1): Parameter 2 (%par2): Return Value Variable: Stop:Off ] If [ %WIFII2 !~ CONNECTION ]
tlaWiFiOff
A1: Variable Set [ Name:%work To:WiFi - Off Do Maths:Off Append:On ]
A2: Variable Set [ Name:%work To:WiFi - Still Off Do Maths:Off Append:Off ] If [ %WIFI ~ off ]
A3: WiFi [ Set:Off ]
... the Wait is needed for it to work.
... Thom
