Note 4 verizon Battery issues
kb0sdq
Howdy,
I am having an issue with my note 4 battery seems like ever since it got 6.01 when my battery gets down to 36% the phone starts boot looping until I either pull the battery or plug in charger. This is driving me crazy as it limits the mobility of this device. Any suggestions would be great.
Doug
I recommend switching the battery asap.... And if you dnt mind bulk... I highly recommend the ZEROLEMON BATTERY case... Cnt go wrong with 3 days on a single charge with heavy use
Howdy FRESHCMB
Thanks for the info I will look into a new battery and check out that Zerolemon battery you mentioned. Will post here if a battery swap does or does not work.
Hope the Note * comes out soon so I can upgrade.
Doug
Hi, I had heard that the Note 8 is being revealed on 26th of this month and will be available then. Phil
Ended up getting another battery and no more issues thanks guys for all the suggestions. The note 4 may live a little longer lol
