johnpjackson
What's the protocol for charging the Note7 battery, to maximize its service life, and its capacity throughout?
Keep it on the charger at all times, except when charging facilities aren't at hand?
Or, charge it full, then use it until some amount partially, or fully, discharged?
Should fast charging mode be used only when necessary, or can it be used exclusively, all the time?
On a related note (yes, that's a pun!!):
At some point recently my Note 7 asked me if I wanted to enable power saving mode. I said yes, and chose the 'medium' strength profile. It has made a huge difference in slowing down my rate of battery discharge. I would say I was seeing about 1/2 to 2/3 of a day of pretty active use eating up most of my charge, before enabling power save mode. Now, it looks like I can easily get through a whole day, without starting to descend into sub-50% remaining charge territory, much, or at all. I'm starting to actually get the urge to not keep the phone plugged into the charger all the time, because of it. Before, I definitely wasn't seeing battery longevity that stirred such thoughts..
