which though? Samsung or Verizon? I bought the phone from verizon.Can't hurt.
The worse they can say is; No.
I didn't want to file a claim on mine because it was going to cost $250, plus I was going to get a used replacement phone.
After reading the notes above, here is what I did. I installed a speaker cleaner app, which sends a sound through the main speaker, called Speaker Dryer. Then I installed Earpiece Speaker Volume Booster to send the Speaker dryer through the earpiece. Both apps are on the Play Store; The earpiece booster had tons of ads but I only used it for a few minutes.
Then I used a soft toothbrush and alcohol and scrubbed the speaker, while playing the Speaker Dryer app over and over for like 15 minutes.
Works great now.
HOLLY SHHHHHHHH...... IT WORKED! Created an account to personally thank you DimplesDelight sir! Used my Oral B Electric Toothbrush + Speaker Dryer + Earpice Speaker Volume Booster! It did the trick.. Beautifully.. Thanks again!I didn't want to file a claim on mine because it was going to cost $250, plus I was going to get a used replacement phone.
Works great now.
