I have a scl24 samsung galaxy note edge AU
When i bought it was unboxed and had a cooked Rom. I found it initially laggy but i didnt mind. Now i installed the latest Rom Sphinx 1BHO3 and my Benchmark score reveals that it only has 36000 points (image below) meanwhile it should be 48k (stronger than note 4 on the internet)
I moved on to install z-cpu to check the specs and they are all same as others (image below). Anyone has the same problem? Very disappointed
And if you are running well on your scl24 please tell me your Rom, i may try it![Frown :( :(](/styles/smilies/google/frown.png)
