Noticably worse battery life after update.
hal1
Android Expert
My battery app tells me time remaining as well as discharge rate. It used to be over 21+ hrs from full, and a discharge rate of 1% per 15 minutes.
Now it's 15-16 hours from full and a discharge rate of 1% per 10 minutes.
Any thoughts or observations on this?
After I choose scroll down to 'recovery', then use the up volume to select it, it comes up the the "no command" under the android on his back. All that I can seem to do is power off and it boots as normal. Never gets to the clear cache options.
That's the explanation mark logo screen. I tweaked the write-up. Try it again at that point hold Volume Up for 10 seconds and select Power when release them both. It takes some practice.
... Thom
That's the explanation mark logo screen. I tweaked the writ-up. Try it again at that point hold Volume Up for 10 seconds and select Power when release them both. It takes some practice.
... Thom
Whammo! Thanks. Also uninstalled/reinstalled the battery app. We'll see how this bad boy looks in the morning.
I don't know if it was the Cache Wipe or the reinstall of my battery app, but all seems good.
Thanks Thom.
