Notification LED
SweenMike
Have tried 4 or 5 add on products that claim to enable a LED notification light on my One+ 7t. So far, other than one turning on the flashlight, nothing has worked. Anyone know of a working LED notification light?
Thanks
I'm pretty sure that that phone doesn't have a notification LED, so no app can enable one.
Do you mean an app to emulate one using the main display? If so which apps have you tried?
(I don't have this phone so can't test apps for compatibility with it, but if you say what you've tried it will help others investigate or avoid people suggesting things which you already tried).
Thanks for your reply. No, the phone doesn't have an LED capability. However, I finally found one that works. It is called Notify Buddy. As you say it emulates an LED. Still testing as it seems to drain the battery, but not sure if it's the new app or just me using my phone more with nothing else to do.
The ones that did not work for me were: Flash Blink, Always on Edge and LED Blinker Notification. Many of these had good reviews, maybe they just don't work well on One Plus.
Best wishes,
Mike
our
just trying out an app called aoled that shows a light around the drop in a always on stylee ....seems cool
