Peaches037
I'm not sure what happened.. Visual voicemail, sms, and a couple of others are no longer notifying me that I have a message.. I no longer see icons at the top left corner either..
I checked the volume and I went into each app to see if I disabled notifications, but they are enabled..
I can't say how long this has happened because I usually have my phone on vibrate.. Even in that instance I would still feel it vibrate and the icon would pop up..
Is there some where else I should be checking? All help is appreciated.
Thank you. 😳
Thank you. 😳
