i just revceived a text that was stamped as being received 15 prior. the problem is that it did not notify me of this while the phone was on SLEEP MODE. This besides the fact that the vibrate sucks. Anyone else having this problem?
Try toggling your notification preferences for text - install the SMS notifying app too (you can uninstall if if you dont like it). Reboot - or hard reset.
I had this problem as well after I got the OTA RC30 update. I had to do a reset of the phone to fix it. In my case, I was not getting any alerts at all. Not just from texts but from emails as well. So, you may want to try a reset.
I didn't have this problem BUT I did have another problem after updating to RC30. My 3g network didn't work and it kept connecting to edge because of it. So I restarted my phone and everything works now. Try restarting after you update, for some reason there are little glitches here and there if you don't restart your phone.
