Help notification sound is for everything! - Galaxy Ace
highway47
Why is my notification sound for a warning for my low battery, Fully charged battery and message tone the same? Can't I choose one for each? If so, how?
Just found the solution. May be late, but may be useful for someone else!!!
You can set different notification saound alerts for email, for calendar note and for SMS text messages.
SMS is simple: settings/sound/notification ringtone
Email: click on gmail (or other mailsupplyer) icon like when you want to check on your mails./click menu key (left of the only button under the screen)/more/settings/click on your account you want to change the sound of/scroll down to email notifications and swith it on (if turned off) / labels to notify/inbox/ringtone. Done!!!
Calendar: same things to do until you get into settings/here you can select ringtones too!
It took days to me to find this out, hope it helps you too!! :hello:
Hi,
Although notification sounds for e-mail, sms, alarm can be set separately, this is not the case with the system notifications like fully charged battery, low battery notification and things like that. At least not without an app (I don't know which one does this though).
Edited: look at the thread right below this one, Socrates0 is giving tips for apps.
