Help Notification sound problems
scaress123
I just bought this phone yesterday and I set my notification sound but it doesn't play this specific sound when I get a text, only when I get emails or any other kind of notification. I thought maybe there was a special setting for messages but I didn't find anything. My husband has the LG Rizio and it has the same UI and he had the same issue. Anyone else come across this problem?
What are you using for your messaging client? Usually the default notification tone is used under menu>settings>sound. If you are using hangouts or the LG messaging app, you might find it under settings for the app.
@scaress123
sometime notification sound are by app default, on your Default Text Message Click the 3 dots on your right top corner and follow this steps :
1- Settings.
2- Notification Settings
3- Notification Sound.
there you can change the Notification sound as you like. or just follow the image
