ironass
Extreme Android User
OnePlus has just begun an incremental, (gradual), rollout of the official  OxygenOS 4.0.1. This update to the OxygenOS Nougat, 4.0, firmware release on the 31st Dec: 2016, has the following..
Links...
OxygenOS 4.0.1 (N) OTA for OnePlus 3
OxygenOS 4.0.1 (N) OTA for OnePlus 3T
[*]Here are the highlights:
[*]Upgraded to Android 7.0 Nougat
[*]New Notifications Design
[*]New Settings Menu Design
[*]Multi-Window View
[*]Notification Direct Reply
[*]Custom DPI Support
[*]Added Status Bar Icon Options
[*]Improved Shelf Customization
[*]Updated APN Settings for select Carriers
[*]Fixed Proximity Sensor bug during calls
[*]Increased System Stability
[*]***Known Issues and Fixes
[*]Apps might not download from Play Store.
[*]If you are trying to download via Data Roaming, it will not work. This is a known Google issue.
[*]Please follow Google’s troubleshooting steps and see if the problem is resolved.
[*]Try turning on Battery Saving Mode and reset Play Store app preferences.
[*]If you have these 3 apps installed: Truecaller, AVG Antivirus and PayTm, please try to force stop or uninstall them before performing download from Play Store.
[*]If you still experience mobile data issues caused by APN, please go to APN settings page and manually choose try all the options.
Links...
