Nubia Z17 Mini Scroll bar removal in Android Assistant
bmaz121
The scroll bar is interfering will a selection box on the right hand side of the screen. I can not find a setting to turn this scroll bar off since I don't need it anyway. Android Assistant startup stopper list the apps to check not to start up. The check box is too close to the edge causing the scroll bar to be activated instead of the check box.
