ilyas khan
Hey
The is the code for my android app it is a app that demonstrates how to communicate with multiple fragments in one activity. But the textview in the text fragment is not being updated after an item of the listview is selected because of a nullpointer exception from the listener I think. The textview should update when an item in the listview is selected but it is not updating, it is not crashing though. Can someone help? Thanks.
fragment_text.xml
activity_main.xml
strings.xml
fragment_text.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<FrameLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:id="@+id/TextFragment_layout1"
android:layout_height="match_parent"
tools:context=".TextFragment">
<TextView
android:id="@+id/textView1"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:padding="16dp"
android:text="[USER=696546]@String[/USER]/welcome" />
</FrameLayout>
Java:
package com.example.tourguide;
import android.content.res.Resources;
import android.net.Uri;
import android.os.Bundle;
import androidx.fragment.app.Fragment;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import android.widget.ArrayAdapter;
import android.widget.ListView;
import android.widget.TextView;
* A simple {@link Fragment} subclass.
* Use the {@link TextFragment#newInstance} factory method to
* create an instance of this fragment.
public class TextFragment extends Fragment
TextView textView;
// TODO: Rename parameter arguments, choose names that match
// the fragment initialization parameters, e.g. ARG_ITEM_NUMBER
private static final String ARG_PARAM1 = "param1";
private static final String ARG_PARAM2 = "param2";
// TODO: Rename and change types of parameters
private String mParam1;
private String mParam2;
public TextFragment() {
// Required empty public constructor
* Use this factory method to create a new instance of
* this fragment using the provided parameters.
* [USER=315340]@param[/USER] param1 Parameter 1.
* [USER=315340]@param[/USER] param2 Parameter 2.
* @return A new instance of fragment TextFragment.
// TODO: Rename and change types and number of parameters
public static TextFragment newInstance(String param1, String param2) {
TextFragment fragment = new TextFragment();
Bundle args = new Bundle();
args.putString(ARG_PARAM1, param1);
args.putString(ARG_PARAM2, param2);
fragment.setArguments(args);
return fragment;
[USER=1021285]@override[/USER]
public void onCreate(Bundle savedInstanceState)
if (getArguments() != null)
mParam1 = getArguments().getString(ARG_PARAM1);
mParam2 = getArguments().getString(ARG_PARAM2);
public View onCreateView(LayoutInflater inflater, ViewGroup container,
View view = inflater.inflate(R.layout.fragment_text, container, false);
textView = (TextView)getActivity().findViewById(R.id.textView1);
return view;
public void updateTextView(int index)
if(index==0)
textView.setText(getResources().getString(R.string.set_Richmond));
else if(index==1)
textView.setText(getResources().getString(R.string.set_Vancouver));
else if(index==2)
textView.setText(getResources().getString(R.string.set_Toronto));
else if(index==3)
textView.setText(getResources().getString(R.string.set_New_West));
else if(index==4)
textView.setText(getResources().getString(R.string.set_Montreal));
else if(index==5)
textView.setText(getResources().getString(R.string.set_Aldergrove));
public interface OnFragmentInteractionListener
public void onFragmentInteraction(int index);
Code:
fragment_list.xml
android:id="@+id/ListFragment_layout1"
tools:context=".ListFragment">
<ListView
android:id="@+id/listView1"
android:dividerHeight="32dp" />
</FrameLayout>
Java:
import android.widget.AdapterView;
* Use the {@link ListFragment#newInstance} factory method to
public class ListFragment extends Fragment implements AdapterView.OnItemClickListener
ListView listView;
String[] array;
String listStr;
OnFragmentInteractionListener listener;
public ListFragment() {
* @return A new instance of fragment ListFragment.
public static ListFragment newInstance(String param1, String param2) {
ListFragment fragment = new ListFragment();
return fragment;
public void onCreate(Bundle savedInstanceState) {
public View onCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState)
View view = inflater.inflate(R.layout.fragment_list, container, false);
listView = view.findViewById(R.id.listView1);
array = getResources().getStringArray(R.array.string_array_cities);
ArrayAdapter<String> adapter = new ArrayAdapter<String>(getActivity(), android.R.layout.simple_list_item_1, array);
listView.setAdapter(adapter);
listView.setOnItemClickListener(this::eek:nItemClick);
return view;
public void onItemClick(AdapterView<?> adapterView, View view, int index, long id)
//if(listener != null)
listener.onFragmentInteraction(index); //pass index of array
activity_main.xml
Code:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
android:id="@+id/LinearLayout_1"
android:eek:rientation="vertical"
tools:context=".MainActivity">
<androidx.fragment.app.FragmentContainerView
android:id="@+id/fragmentContainerView1_list"
android:name="com.example.tourguide.ListFragment"
android:layout_height="0dp"
android:layout_weight="1"
tools:layout="@layout/fragment_list" />
android:id="@+id/fragmentContainerView2_text"
android:name="com.example.tourguide.TextFragment"
tools:layout="@layout/fragment_text" />
</LinearLayout>
Java:
import androidx.appcompat.app.AppCompatActivity;
import androidx.fragment.app.FragmentManager;
import android.app.Fragment;
public class MainActivity extends AppCompatActivity implements TextFragment.OnFragmentInteractionListener, ListFragment.OnFragmentInteractionListener
protected void onCreate(Bundle savedInstanceState)
setContentView(R.layout.activity_main);
FragmentManager manager = getSupportFragmentManager();
TextFragment textFragment = (TextFragment)manager.findFragmentById(R.id.fragmentContainerView2_text);
textFragment.updateTextView(index);
strings.xml
Code:
<resources>
<string name="app_name">Tour Guide</string>
<string name="hello_blank_fragment">Hello blank fragment</string>
<string name="text_box">default</string>
<string name="welcome">Welcome to the Tour Guide App</string>
<string name="set_Richmond">Richmond is a quite city with many nice hidden scenic places. A small town named Steveston is found on the south west part
of the city and is well known for having good seafood and nice places to visit like Garry Point and the west and south dykes. </string>
<string name="set_Vancouver">Vancouver is one of Canadas biggest cities and has a lot to offer like the malls and many towers, beaches, parks.</string>
<string name="set_Toronto">Toronto is Canadas biggest city on the east coast and home to the TSX and Maple Leafs.</string>
<string name="set_New_West">New West is a city east of Vancouver but close by and has nice parks and ice rinks like Moody Park and Queens Park.
Queens Park home of the New West Royals.</string>
<string name="set_Montreal">Monteal is famous for their smoked meat and they speak french.</string>
<string name="set_Aldergrove">Aldergrove is a quite town and is east of Langley not too far and is a nice place.</string>
<string-array name="string_array_cities">
<item>Richmond</item>
<item>Vancouver</item>
<item>Toronto</item>
<item>New West</item>
<item>Montreal</item>
<item>Aldergrove</item>
</string-array>
</resources>
