Number transfer to my flashed evo 4g (boost)
dayzbaby
So i have a boost number and a htc 4g evo that is flashed to boost so now i want to transfer my number to my 4g evo... how do i find the meid so i could go to boost mobiles website and enter that number and transfer my number. . .
On your HTC dial in ##786# you'll get the meid for the device. Dec and hex. The dec goes to the boost website.
After you put the dec into the website and that's your device you can press menu from the ##786# page and one of the options should be "reset". Select it and the device will ask for your MSL/SPC. Put it in and the phone will reset. If after 10-20 seconds it does not reboot itself, reboot it manually. When it comes back up it will do an OTA activation... that should activate your phone.
Good luck.
