Help Odin help
burak
If i upgrade to jelly bean 4.1.1 with odin will i lose my data on the mobile or will my data still be there
As stated above you won't lose data if running a stock ROM & upgrading to a stock ROM.
It'll be plugged into the PC/laptop if you're doing it that way so don't worry about battery level (I never did anyway)
I used mobile Odin to unroot my phone yesterday back to a stock ROM. I didn't lose any data and was able to get the OTA update for JB.
Odin flashes partitions, so it depends on the file you are using; some wipe, some don't.
I would like to move this to the ATR forum for better visibility but I don't know who your provider is.
