FriedBunny
In attempting to flash from stock 1.6 to a modified ROM (bearsfan's, microhaxo's), somehow I managed to wipe out the OS partitions (but none of the boot) and yet Odin refuses to finish a flash - it just stalls at the point where it should write the system partition(s).
None of the stock packages I found on this forum will flash, either (T939UVJA3 1.5 or T939UVJE2 1.6). Trying to flash phone and pda together AND separately both fail, as does the use of any One Package.
Occasionally it appears to be working and the progress bar will move, but download mode never spits out any "OKAY" acknowledgement onto the phone's screen. BH_MAN's modified recovery partition loads, but ultimately only comes up with a "5%" screen and stops.
I've tried to flash on three different computers, Windows 7 and XP (all 32bit); also tried direct usb and with a powered hub. I've tried Odin 3.88 and 4.03. Odin 3.88 seems to work the best, but the two progress bars move until the bottom red one finishes and then it stalls - phone doesn't acknowledge a PDA flash or reboot.
Powering on will show the cartoon phone connecting to the computer icon. Stock recovery mode fails and tries to load into download mode, but shows white bars at the top and bottom. Download mode loads and connects.
So at this point I'm simply befuddled. Did I somehow corrupt the nand so that now it won't accept system flashes? Should I have rooted and fiddled around with adb first before trying to Odin? Arrrrrg!
