Oem unlock in build prop
andriodadmirer
If I have a u.s samsung that doesn't allow
Bootloader unlocking
But I looked inside the build.prop
And it has the line of ro. Oem unlocking =1
The 1 means it's allowed right ? So
In theory if that is already set
All I need is to have the developer options show me the oem unlocking tick right
With that said could I just replace the sec settings.apk with another from another country and put in mine as long as it's android 13 and from samsung
Put it inside the firmware
Flash the firmware through odin
I shouldn't get an error because it's all stock and signed by samsung then I should be able to get it back in developer options
But I also think I read something that stated that developer options ( oem unlocking ) has to be enabled from the bools.xml file inside the decompiled framework-res.apk
Am I crazy or does this sound like it would work ???? Please help
