The LG Motion now has a 2nd init recovery, the Motion and Regard are almost identical phones, so this recovery should work on your phone.
There is a CM10 pre-alpha that should work on your phone too
There is a base de-odexed ROM, you guys can NOT use the ROM itself, but you should be able to use the update script and update binary to make your own ROMS
The recovery and CM10 is the work of a developer name 985hPaKicK
I was able to figure out that the recovery worked as-is on the Motion, and I was able to make his CM10 work on the Motion with some slight modifications, so if you use any of this stuff, please post a thank you post for 985hPaKicK in this thread
http://androidforums.com/motion-4g-all-things-root/666214-thank-you-thread-985hpakick.html
Recovery
http://androidforums.com/motion-4g-all-things-root/665972-985hpakick-2nd-init-recovery.html
CM10
http://androidforums.com/motion-4g-...cyanogenmod-10-pre-alpha-985hpakick-kang.html
Base de-odexed ROM (do not install on the Regard)
http://androidforums.com/motion-4g-all-things-root/666429-base-de-odexed-rom.html
Maybe if the Motion and Regard forums work together we can get the CM10 fully working
Since there are differences between the two phones it would be better to post Regard specific issues/bugs in this thread and not in the LG Motion threads
If you would like to buy me a beer or coffee, you can click on the Donate button
Recovery
CM10
