mcpixel
This main code:
MyWorker.java:
After starting the application, I see the following in logcat:
What could be the problem? It seems to me that something is wrong with the code. I tried to do this:
But nothing happened because the code just doesn’t want to run and nothing is clear from the documentation
Java:
package com.example.app3;
import androidx.appcompat.app.AppCompatActivity;
import androidx.work.ArrayCreatingInputMerger;
import androidx.work.Constraints;
import androidx.work.Data;
import androidx.work.OneTimeWorkRequest;
import androidx.work.WorkManager;
import android.os.Bundle;
import java.util.Arrays;
import java.util.concurrent.TimeUnit;
public class MainActivity extends AppCompatActivity {
@Override
setContentView(R.layout.activity_main);
OneTimeWorkRequest o1 = new OneTimeWorkRequest.Builder(MyWorker.class)
.setInputData(new Data.Builder().putString("name", "number1")
.build())
.build();
OneTimeWorkRequest o2 = new OneTimeWorkRequest.Builder(MyWorker.class)
.setInitialDelay(2, TimeUnit.SECONDS)
.setInputData(new Data.Builder().putString("name", "number2")
.putInt("number", 2).build())
.build();
OneTimeWorkRequest o3 = new OneTimeWorkRequest.Builder(MyWorker.class)
.setInputMerger(ArrayCreatingInputMerger.class)
.setInputData(new Data.Builder().putString("name", "number3")
.build())
.setConstraints(new Constraints.Builder().setRequiresCharging(true).setRequiresBatteryNotLow(true).build())
.setInitialDelay(2, TimeUnit.SECONDS).build();
WorkManager.getInstance(getApplicationContext())
.beginWith(Arrays.asList(o1, o2))
.then(o3)
.enqueue();
Java:
import android.content.Context;
import android.util.Log;
import androidx.annotation.NonNull;
import androidx.work.Worker;
import androidx.work.WorkerParameters;
public class MyWorker extends Worker {
public MyWorker(@NonNull Context context, @NonNull WorkerParameters workerParams) {
super(context, workerParams);
@NonNull
@Override
public Result doWork() {
int number = getInputData().getInt("number", 0);
Data ret = new Data.Builder().putInt("number", number*2).build();
Log.e(getInputData().getString("name"), ""+number*2);
return Result.success(ret);
Code:
08-03 23:57:16.188 26949-26968/com.example.app3 E/number1: 0
08-03 23:57:16.226 26949-26965/com.example.app3 I/WM-WorkerWrapper: Worker result SUCCESS for Work [ id=ec6086ea-b8d4-41e6-9bff-936fe2c157b3, tags={ com.example.app3.MyWorker } ]
08-03 23:57:18.046 26949-26974/com.example.app3 E/number2: 4
08-03 23:57:18.047 26949-26964/com.example.app3 I/WM-WorkerWrapper: Worker result SUCCESS for Work [ id=93a8312e-aa31-41d0-97b2-35d4d49668db, tags={ com.example.app3.MyWorker } ]
08-03 23:57:18.050 26949-26964/com.example.app3 I/WM-WorkerWrapper: Setting status to enqueued for a0fc4f5c-a9da-4bfd-b91a-428e5c67c56b
08-03 23:57:20.076 26949-26965/com.example.app3 I/WM-WorkerWrapper: Worker result SUCCESS for Work [ id=a0fc4f5c-a9da-4bfd-b91a-428e5c67c56b, tags={ com.example.app3.MyWorker } ]
Java:
if("number3".equals(getInputData().getString("name"))) {
int[] nums = getInputData().getIntArray("number");
assert nums != null;
Log.e("TEST", "" + nums.length);
