onFatalError, processing error from engine(4)
I am getting the following error on logcat repeatedly.I am also posting my gradle informations.
com.google.android.googlequicksearchbox:search W/ErrorProcessor: onFatalError, processing error from engine(4)
com.google.android.apps.gsa.shared.speech.b.g: Error reading from input stream
at com.google.android.apps.gsa.staticplugins.recognizer.j.a.a(SourceFile:28)
at com.google.android.apps.gsa.staticplugins.recognizer.j.b.run(SourceFile:15)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:457)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at com.google.android.apps.gsa.shared.util.concurrent.a.ax.run(SourceFile:14)
at com.google.android.apps.gsa.shared.util.concurrent.a.bl.run(SourceFile:4)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
at java.lang.Thread.run(Thread.java:764)
at com.google.android.apps.gsa.shared.util.concurrent.a.ai.run(SourceFile:6)
Caused by: com.google.android.apps.gsa.shared.exception.GsaIOException: Error code: 393238 | Buffer overflow, no available space.
at com.google.android.apps.gsa.speech.audio.Tee.f(SourceFile:103)
at com.google.android.apps.gsa.speech.audio.au.read(SourceFile:2)
at java.io.InputStream.read(InputStream.java:101)
at com.google.android.apps.gsa.speech.audio.ao.run(SourceFile:18)
at com.google.android.apps.gsa.speech.audio.an.run(SourceFile:2)
03-24 15:35:38.429 2681-8715/com.google.android.googlequicksearchbox:search I/AudioController: internalShutdown 03-24 15:35:38.444 2681-2681/com.google.android.googlequicksearchbox:search I/MicroDetector: Keeping mic open: false 03-24 15:35:38.444 2681-2681/com.google.android.googlequicksearchbox:search I/MicroDetectionWorker: #onError(false) 03-24 15:35:38.446 2681-11725/com.google.android.googlequicksearchbox:search I/DeviceStateChecker: DeviceStateChecker cancelled 03-24 15:35:39.909 12694-12694/? D/AndroidRuntime: >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<< 03-24 15:35:40.007 12694-12694/? W/app_process: Unexpected CPU variant for X86 using defaults: x86 03-24 15:35:40.051 12694-12694/? D/AndroidRuntime: Calling main entry com.android.commands.wm.Wm 03-24 15:35:40.072 1736-4225/system_process W/WindowManager: Permission Denial: dismissKeyguard from pid=12694, uid=2000 requires android.permission.CONTROL_KEYGUARD 03-24 15:35:40.073 12694-12694/? D/AndroidRuntime: Shutting down VM
my build-gradle(module) file has
dependencies {
implementation fileTree(dir: 'libs', include: ['*.jar'])
implementation 'com.android.support:appcompat-v7:26.1.0'
implementation 'com.android.support.constraint:constraint-layout:1.0.2'
testImplementation 'junit:junit:4.12'
androidTestImplementation 'com.android.support.test:runner:1.0.1'
androidTestImplementation 'com.android.support.test.espresso:espresso-core:3.0.1'
compile 'com.google.android.gms:play-services:8.4.0'
my build_gradle (project) file has following
dependencies {
classpath 'com.android.tools.build:gradle:3.0.1'
classpath 'com.google.gms:google-services:3.1.1'
