Open home skins - small analog clock
Psyclone
All,
I'm running open home and have an issue with skins and the default analog clock widget with the problem being that once I switch to the open home big analog clock and switch back to the regular analog clock widget that it is no longer skinned with the currently enabled skin, it just has the default android skin and nothing I do will cause it to skin the regular clock widget with the currently enabled skin.
It seems that only after you install open home will it skin the regular analog clock widget but once you change it to big clock and back again it will never reskin it.
Any open home users know how to fix this?
