Hello friends!
I would like to ask you a little help.
Im trying to develop an application using openGl but when I run it the it closes.
All that Im trying to do is get vertex values from a string and them draw it using openGl.
Its my first time posting at forum list. Sorry about any mistake and since now thanks guys
Code:
public class Objeto3D extends Object {
//Buffers do objeto
private ShortBuffer _indexBuffer; //indices com a ordem que deve ser desenhado
private FloatBuffer _vertexBuffer; //vertices
private FloatBuffer _normaxBuffer; //normais
//private FloatBuffer _corexBuffer; //cores
private short[] _indicesArray;
private int _nrOfVertices = 4;
public String str_indices = "4,0,1,2,3,4,2,4,1";
public String str_vertices = "-1.000000,1.000000,0.000000,-1.000000,-1.000000,0.000000,1.000000,-1.000000,0.000000,1.000000,1.000000,0.000000,0.200000,0.100000,0.000000";
public String str_normais = "-0.000000,0.000000,1.000000,-0.000000,0.000000,1.000000,-0.000000,0.000000,1.000000";
public String str_cores = "0,1,0,0,1,0,0,1,0";
public float[] coordV;
public float[] coordN;
public float[] coordC;
public Objeto3D()
ajustarForma(str_indices, str_vertices, str_normais);
private void decodificarVertices()
String coordIndices[] = str_indices.split(",");
String coordenadas[] = str_vertices.split(",");
String coordNormais[] = str_normais.split(",");
//String coordCores[] = str_cores.split(",");
coordV = new float[coordenadas.length];
coordN = new float[coordNormais.length];
coordC = new float[coordenadas.length];
_indicesArray = new short[coordIndices.length];
for(short i=0;i<coordenadas.length;i++)
coordV[i] = Float.valueOf(coordenadas[i]);
// coordC[i] = Float.valueOf(coordCores[i]);
for(short i=0;i<coordIndices.length;i++)
_indicesArray[i] = Short.valueOf(coordIndices[i]);
for(short i=0;i < coordNormais.length;i++)
coordN[i] = Float.valueOf(coordNormais[i]);
_nrOfVertices = coordenadas.length;
private void initShape() {
// float has 4 bytes
ByteBuffer vbb = ByteBuffer.allocateDirect(_nrOfVertices * 3 * 4);
vbb.order(ByteOrder.nativeOrder());
_vertexBuffer = vbb.asFloatBuffer();
//float has 4 bytes;
ByteBuffer nbb = ByteBuffer.allocateDirect(_nrOfVertices * 3 * 4);
nbb.order(ByteOrder.nativeOrder());
_normaxBuffer = nbb.asFloatBuffer();
/*/ float has 4 bytes
ByteBuffer cbb = ByteBuffer.allocateDirect(_nrOfVertices * 3 * 4);
cbb.order(ByteOrder.nativeOrder());
_corexBuffer = cbb.asFloatBuffer();*/
// short has 2 bytes
ByteBuffer ibb = ByteBuffer.allocateDirect(_indicesArray.length * 2);
ibb.order(ByteOrder.nativeOrder());
_indexBuffer = ibb.asShortBuffer();
_vertexBuffer.put(coordV);
_normaxBuffer.put(coordN);
//_corexBuffer.put(coordC);
_indexBuffer.put(_indicesArray);
_vertexBuffer.position(0);
_normaxBuffer.position(0);
//_corexBuffer.position(0);
_indexBuffer.position(0);
public void desenharObjeto(GL10 gl)
// Counter-clockwise winding.
gl.glFrontFace(GL10.GL_CCW); // OpenGL docs
// Enable face culling.
gl.glEnable(GL10.GL_CULL_FACE); // OpenGL docs
// What faces to remove with the face culling.
gl.glCullFace(GL10.GL_BACK); // OpenGL docs
// Enabled the vertices buffer for writing and to be used during rendering.
gl.glEnableClientState(GL10.GL_VERTEX_ARRAY);// OpenGL docs.
// Define a cor do elemento a ser desenhado
//gl.glColor4f(0.0f, 0.5f, 0f, 0.5f);
//gl.glColorPointer(3, GL10.GL_FLOAT, 0, _corexBuffer);
float white[] = new float[] { 1f, 1f, 1f, 1.0f};
float red[] = new float[] { 1f, 0f, 0f, 1.0f};
gl.glMaterialfv(GL10.GL_FRONT_AND_BACK, GL10.GL_DIFFUSE, red, 0);
gl.glMaterialfv(GL10.GL_FRONT_AND_BACK, GL10.GL_AMBIENT, white, 0);
// Define os vertices que desejam desenhar
gl.glVertexPointer(3, GL10.GL_FLOAT, 0, _vertexBuffer);
//Define as normais
//gl.glNormalPointer(GL10.GL_FLOAT, 0, _normaxBuffer);
// Desenha os vertices
gl.glDrawElements(GL10.GL_TRIANGLES, _nrOfVertices, GL10.GL_UNSIGNED_SHORT, _indexBuffer);
// Disable the vertices buffer.
gl.glDisableClientState(GL10.GL_VERTEX_ARRAY); // OpenGL doc
// Disable face culling.
gl.glDisable(GL10.GL_CULL_FACE); // OpenGL docs
public void ajustarForma(String indices, String vertices, String normais)
str_indices = indices;
str_vertices = vertices;
str_normais = normais;
decodificarVertices();
initShape();
