llarryyllarryy
[GALLERY=media, 1652]2022_05_18_22.12.09~2 by llarryyllarryy posted May 26, 2022 at 8:19 AM[/GALLERY]
Those Max Impact Search Engine combines available positive Search Engines for max effect, read more about those engines below.
Advertising is often seen in a negative light, but there are many ways that it can be used for good. And the search results still get delivered with the main search engine so you will not notice a big difference. You could use a search engine like Ecosia to help plant trees.
As the name says, with an impact search engine, you will generate a positive influence (impact) with your searches. You can find multiple search engines with various different causes.
Website: https://llarryyllarryy.github.io/Max-Impact-Search/
Playstore:
https://play.google.com/store/apps/details?id=com.larry.maximpactsearch
Source Code:
https://github.com/llarryyllarryy/Max-Impact-Search/
Playstore:
Source Code:
