I have just move my development environment over to Open Suse 11.2 from Ubuntu as OpenSuse runs a much more modern version of Mono and Monodevelop.
For my Android Dev I have installed Eclipse and the Android SDK
I have an issue getting the ADB (Android Debug bridge) working under OpenSuse. I am trying to connect it to an Archos 5 Internet Tablet. Again this is all working on Ubuntu so its not the Archos but I'm hoping there are other OpenSuse Archos Devs out there...
Heres what I have so far, I'm going to take you though it slowly.
1) Plug in the device.
tail -f /var/log/messages
Jun 7 12:12:36 linux-fius kernel: [ 125.224026] usb 1-7: new high speed USB device using ehci_hcd and address 7
Jun 7 12:12:36 linux-fius kernel: [ 125.356994] usb 1-7: New USB device found, idVendor=0e79, idProduct=1361
Jun 7 12:12:36 linux-fius kernel: [ 125.357003] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 7 12:12:36 linux-fius kernel: [ 125.357009] usb 1-7: Product: Archos5
Jun 7 12:12:36 linux-fius kernel: [ 125.357014] usb 1-7: Manufacturer: Archos
Jun 7 12:12:36 linux-fius kernel: [ 125.357018] usb 1-7: SerialNumber: A5H-69A00004-00000000-040364FD-0201A01B
Jun 7 12:12:36 linux-fius kernel: [ 125.357165] usb 1-7: configuration #1 chosen from 1 choice
As you can see it is detected. If you place the device in Mass storage mode and plug it in you can access it browse it etc. I defiantly have the Devices USB connection in Debug Bridge ADB Mode. I set it and rebooted the device then checked it.
I have created a udev/rules.d/99-android.rules file as follows and restarted udev, (Have also tried rebooting PC).
cat /etc/udev/rules.d/99-android.rules
SUBSYSTEMS=="usb", ATTRS{idVendor}=="0e79", MODE="0666", SYMLINK+="android_adb"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="0e79", MODE="0666", SYMLINK+="android_fastboot"
THis is whats /dev look like once you plug Archos device in.
linux-fius:/home/michael/dev/android-sdk-linux_86/tools # ls -l /dev/an*
lrwxrwxrwx 1 root root 15 2010-06-07 12:12 /dev/android_adb -> bus/usb/001/007
lrwxrwxrwx 1 root root 15 2010-06-07 12:12 /dev/android_fastboot -> bus/usb/001/007
While in Root Terminal.
linux-fius:/home/michael/dev/android-sdk-linux_86/tools # ./adb version
Android Debug Bridge version 1.0.26
linux-fius:/home/michael/dev/android-sdk-linux_86/tools # ./adb kill-server
linux-fius:/home/michael/dev/android-sdk-linux_86/tools # ./adb devices
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
^^^^^^^ As you can see no devices are listed.
I am stuck as to where to go from here. This *should* be working. If anyone has any suggestions I would be grateful as its holding up my software development.
Thanks
Michael B
Thanks
Michael B
