X xuphys Lurker Aug 19, 2014 #1 I installed opera for android, but it seems there is no way to add a speed dial. Can anyone confirm this? Thanks!
Crashdamage Android Expert Aug 19, 2014 #2 I'm confused. Opera is a web browser. It has nothing to do with making calls or speed dialing.
X xuphys Lurker Aug 19, 2014 #3 It's the name of a functionality in Opera, similar to bookmarks, but allowing more "speedy" access.
tommo47 On Yer Bike, In Yer Chair VIP Member Aug 19, 2014 #4 xuphys said: I installed opera for android, but it seems there is no way to add a speed dial. Can anyone confirm this? Thanks! Click to expand... Hi xuphys, welcome to Android Forums. It is possible to add to your speed dial list but unlike Opera Mini and Opera Classic you can't do it from the speed dial page. When you are on the web page you want to save tap the + at the left hand side of the address bar, you will see 'add to speed dial' is an option. If you go to Settings - Help - Frequently asked questions, there is a fairly comprehensive guide to this and other features. Hope this helps.
