Optimus 4x p880 2500mAh battery
I poked around looking for battery of LG Optimus 4x p880 and there are some with same dimension but higher capacity. The one I bought from mpj required my phone drained till it died and then charge to 100% (repeat several times). It REALLY a little bigger than my stock! Some days I get 40+ hrs of use out of my device. Surely it has shorter life as they have claimed, but I don't care. All I know it has getting better.
SOP for any new battery (including the one that comes in a new phone). Three times should be enough. It conditions the battery (in case it's been sitting in a hot warehouse for 6 months before you got it.)
BTW, the amount of time you should get from one charge? That's for "normal use", and there is no such ting. It's a (very) rough estimate.
