Found the recovery boot is "volume down, home button, power button" Hold the first two down then push your power until the lg logo shows up and let go.
Once in Recovery there will be an option to restore the system. Beware that it may erase all your data and settings, as if you had just brought the phone home from the store. Remove your SD card before you do it. You may need to get creative with the buttons to find which ones navigate and select in Recovery.
Hopefully someone with experience with your model can help with something less destructive, but if not, that will work.
