Actually Leon you should have Android 6.0 already. Go into Settings Scroll down to About and tap on Software information to check. Nougat Will be 7.0 when you get it and you will get it.
What's your source? As per Sammobile reports, Samsung is already testing Nougat on the S7 and Edge, plus they've said that Grace UX and the new AOD would come with that update.
