gatleygreen
Hi everyone,
My OTT TV M8 Box arrived last night.
I set it up as follows;
HDMI lead from box to tv
Power cable from box to plug
Reset my dlink router as I'd forgotten my password
Connected to WIFI
At this point, everything seemed to be going well. When I tried to connect to any of the apps, it wouldn't work. I tried to connect to google and it timed out as though there was no internet connection.
But the network settings clearly showed that I was connected to the wifi. My laptop internet was working fine also.
I reset the router - turned the power off for 30 second and re boot the router - unplugged the android box and still the apps and internet wouldn't work.
Any ideas?
Connected to WIFI
Any ideas?
