Hi all
first post (after the introduction..) so go easy on me
im sat on the sofa looking at the gui for my brand new OTT TV box (fully loaded) via ebay. GREAT, SUPER!
sorted the basics , networked, plugged into the telly, and was about to set the date n time correctly or more than likely point it at a time server if the option exists?
I navigated through settings to 'Other settings' and its all in what i think is Chinese???????????
I guess im looking for a new image to flash onto the box? Or is there a different solution?
According to the settings display my OTT TV box is model : HD18Q
running Android Version :4.4.2
kernel Version : 3.10.33
any help will be much appreciated.
tia .
im sat on the sofa looking at the gui for my brand new OTT TV box (fully loaded) via ebay. GREAT, SUPER!sorted the basics , networked, plugged into the telly, and was about to set the date n time correctly or more than likely point it at a time server if the option exists?
tia .
