LaTuFu Android Expert Jun 6, 2011 #2 The stock software will not operate the camera if it is in a low battery state.
King Mustard Well-Known Member Jun 6, 2011 #3 LaTuFu said: The stock software will not operate the camera if it is in a low battery state. Click to expand... Which is why I'm hoping there is a mod around that will sort this annoyance out.
LaTuFu Android Expert Jun 6, 2011 #4 Your OP wasn't very clear about that. If there is any kind of "fix" for it, the most likely source for it will be found on the XDA forum.
M m_usman_ch Newbie Oct 29, 2011 #5 If you're really looking for specific solution try this app: https://market.android.com/details?id=thepaksoft.net.lowbatterycamera Its Low Battery Camera App which serve the exact purpose .
