Pinmac1
I have a Galaxy Note running stock 4.1.2 Android. Over the last couple of days my battery usage has gone mad and only lasting 8-9 hours. I thought it was a duff battery and put my spare in but same result. When I looked at the battery usage I found that Package Access Helper was top of the list with 35% when it never shows usually. I Googled the problem but there was nothing very helpful.
I am also having trouble downloading any apps or deleting cache. I have rebooted several times, done a battery pull and have re-enabled all the apps I had disabled. It has made no difference and the PAH continues to hammer my battery.
Does anyone have any suggestions please as my phone isn't usable for a full day at the moment?
