Apps palying flash in andoid emulator and in device
andstud2011
Hi
i'm in a big problem ,does android support flash,if yes then is that the ordinary flash that we are using in browser or is there any specialty.
Currently i'm in windowsxp,eclipse (helios)with adt plugin, with android 2.3.1 with api level 9
using the emulator how can i use a flash to play in android
going through lot og googling i'm not getting any solution
what is adobe air etc.......
is this site telling is correct
http://www.actionscript.org/forums/showthread.php3?t=241683
what all things has to do to include my flash or any other swf file (mainly from Games at Miniclip.com - Play Free Online Games.)
do i has to create new swf file specially for android by the "AIR runtime FroYo "
please explain me
and has it has to work in the emulator (what all stepups has to done)and in physcial device also
please expalin me
please help me
hi thanks for reply
but my problem is not solved ,from where do i start ,is there any special IDE for developing apk for the flash to play in hte android .
please correct me and give me a starting point to android with flash not FLEX
i had gone through the links that you mentions
is these are correct
Creating your first Flex based Adobe AIR application on Android | Adobe Developer Connection but this is flex
Android Air development using Ant & ADT for FDT 4 | Flash Lounge here uses "FDT 4" is this correct
please help me in starting "FLASH WITH ANDROID"
I INSTALLED "Runtime_Emulator_Froyo_20100930.apk" IT SHOWS ADOBE AIR IN ANDOID'S MANAGE APPLICATION
THEN WHERE TO START
I'M NEW IN ADOBE (FLASH,AIR,ANDROID)
THANKS FOR MORE HELPS
