Ok i downloaded PandaHome and LOVE IT , i spent 2 hours customizing a theme with 7 pages of widgets and different icon packs. it was rocking and going all smooth . I exported what i did to the SD card.
then today i said hey i want to try a different theme (every one raves about the dark hero). well i applied it and ALL MY WIDGETS WERE GONE!!!!!!
I said ok i will just import the theme i customized from the SD card. did that and applied it. IT DIDNT WORK. the theme came over but the widgets need to be all set up again and the worst part I HAVE TO SET ALL MY ICONS AGAIN
is there a way to avoid that again or is it just the way it is?
