I just downloaded pandahome and I'm trying to figure some things out. Like what other themes will open under panda. Does GDE work under panda. Also I'm having a problem with my mall icon not showing emails it only notifies me through the notifications bar
A search in the market will reveal a plethora of themes you can use, unfortunately I don't believe GDE themes are one of them. Openhome, freshface etc themes are all mostly compatible.
GDE and Pandahome are 2 different home replacements and only 1 home replacement can be viewed simultaneously at any time. so basically you can only view one but you can run both - install both on your phone -> press the home button on your phone and select either Pandahome or GDE
The default mail icon does not show you how many unread emails you have and does notify you in the notification bar , there is a widget on the market however which can show you this. It is a paid app though @ 59p i believe
