I had this problem at first; the drivers you need to install are on the phone, but it's not obvious how to get at them. You can't install them with the phone's SD card set to function as an external removable drive.
A quick guide:
1: Create a new folder on the desktop and open it.
2: Disable the Autorun feature of Windows; it may not help, but it won't hurt either.
3: Connect the phone after opening Windows Explorer and open the drive that appears.
4: This part is tricky; while the drive is open, copy ths files to the folder on the desktop. You may need to repeat this step a few time..
5. Once you have successfully copied the files, run the bootstrap program; these are the files that you need to be able to consistently connect to the phone.
