Well I have a pantech burst that has done the same thing. I've taken it completely apart to check for any corrosion or anything of the sort, but i have nothing. I even took the battery and got it charged to the maximum and the phone still wont turn on.
Let me give you a few suggestions I found though it didn't work for me it may work for you. IF your battery life was totally drained you may have to revive your battery. I would give you a link but im new so Im not allowed to just yet. You take an old charger or usb cut it , take the positive and negative of the wires and connect them with the positives and negatives on the battery. Look this up for the complete instructions.
you may want to try taking the battery out , plugging the phone in the computer (without) the battery then put the battery in, vice versa and what other combinations you may find.
let me know if you figure something out as well
