Pantech PC Suite
Lanky
Member
For those of you that are interested, there is a PC Suite from Pantech to use for your phone. There isn't one listed for the Discover on the Discover page, but I downloaded the one from the Crossover (P8000) and it works perfectly fine. Here is the link if you are interested in giving it a try:
PANTECH PC SUITE
I like the software UI and no glitches :D
Thanks. It was nowhere on the Pantech website also for the Hotshot phone. Although it shows up on the Crossover page, it doesn't appear to have a working link to download PC Suite (I'm using Chrome). Their email support page at http://www.pcdphones.com also seems to be dead. Looks like a company on the outs. Lanky, if you have the PC Suite installer file, could you post it? It seems to be called Nata.exe.
I'm also looking for the file? The Pantech site is down and the Korean site has no trace of the software
P8000PantechPCSuite_1.1.1.3437.exe
