Apps Passing Intents to start Activities
rishi360
Hey guys.
I'm trying to make a program where you start out with a grid of pictures. I got it working to the point where if you tap one of the pictures, a RelativeLayout with some text (a different activity that uses a separate layout depending on which picture you pressed) opens up. What I CAN'T get to work is to get the grid to open up a GalleryLayout or ListView. Both ways have force closed any time I try to press one of the pictures. I'm passing an Intent and using startActivity() [which worked for the RelativeLayout] but it won't work for RelativeLayout or GalleryLayout.
Help?
Thanks!
I have never personally used a gallery layout, but for a ListView, have you tried extending ListActivity instead of the usual Activity class?
the ListActivity class contains all of the functionality of a standard Activity class with some extra implementations for ListViews. It eases the process greatly.
Here is an example implementation:
public class MitsuMediaGUI extends ListActivity
@Override
public void onCreate(Bundle savedInstanceState)
setContentView(R.layout.main);
@Override
protected void onListItemClick(ListView l, View v, int position, long id)
super.onListItemClick(l,v,position,id);
if(position == 0)
startActivity(new Intent(MitsuMediaGUI.this,RoTM.class));
