I copied everything I could from the SD card to the PC under pictures. Of course not all of that is pictures but I can sort that out later. The problem is that it says some things are available only online, which the PC is not, and some files it claims are empty. It apparently isn't going to display a lot of pictures either. I don't know why it's doing this. The last time I hooked up the SD card (just that, not the phone) it automatically found and copied a whole lot of files. This time it had some weird message about how the card might have something wrong with it and that it should be scanned. I told it to do that, which took maybe a second, and then it said it was fine. I still had to tell it to copy (select all, copy to pictures). What's the problem?
