infamoushugs
Hello Android forums,
My question is simply can I send (drag and drop) videos from my pc into my g1?
Sorry if someone else asked this and you already answered it, but I was unable to find that thread.
What I'm doing is mounting the g1 to my pc and then after I open my g1 files using IE I then drag and drop the videos into the dcim/ camera folder just like I usually do with my songs.
But after i remove the usb and I look for the video I don't see it.
Can it be done using this method or is there another way?
Thanks everyone
Thanks everyone
