PCD Chaser Screen flickering on custom rom
alan2121m
I installed the custom rom for a pcd chaser and everytime I click on anything the screen starts flickering has anybody found a solution to this thanks in advance.
Check you haven't got "Show screen updates" ticked in the Developer options in Settings. Failing that could be a problem with that particular custom ROM, which the devs would have to fix.
can you be a little more detailed, the only development option that I see in settings is under applications then development then opens the options like to check off allow debugging can u please help
