PDAnet and Lolipop 5.1.1
Sept1967
So Im guessing the Lolipop 5.1.1 update kills USB tethering with PDAnet?
Paid registered version. Working for over a year.
Metro LG Stylo used to work with 5.0.2 - I just tried first time since the 5.1.1 update.
It wont connect with Use Google DNS checked on. Uncheck it, it connects, then after 5-10 mins, stops working. Shows connected, but no data to pc. Reinstalled both pc and phone app. tried 3 different LG adb drivers, including the ones PDAnet loads on install, and the newest ones with LG Bridge. Tried usb connected as a camera PTP, and a media device MTP.
I tried it on an AMD, and Intel pc's, both using Windows 7. Same result.
Swapped the sim to another Metro phone, using Kitkat 4.4 - still works as it should on both pc's
With Google DNS checked.
