Help Personalised Ringtones for Contacts
andyr12345
Hello, I have just got myself a Galaxy note 3 N9005 LTE and have assigned a ringtone to a contact in mp3 format. The mp3 is a name of the contact, and what is happening is that when the contact rings it repeats the name (mp3) over and over again repeatedly until I answer with no pauses in it.
Hard to explain but I will try: - lets say the contact's name is Valerie , so i have it saying "Valerie Calling" - so when valerie calls my phone goes "Valerie Calling, Valerie Calling, Valerie Calling" like that with no silence in between - what I would like is "Valerie Calling (3second silence) Valerie Calling (3second silence) Valerie Calling (3second silence)
Does anyone know how I can get it to ring like that? - if I changed it from an mp3 to an aac file (or whatever the normal ringtone format for galaxy phones are) would that do it do you think?
Thanks.
Try Talking Ringtone Maker Pro from the play store. Just add 3 seconds of silence to the end of your recording
Thanks, have tried this app before on another android phone - I dont know if its possible to add a 3 second silence though, I wonder how it would be possible .. unless you press spacebar 3 times maybe. - I will try it out again.
Try shorting that vocal recording time of that personal ringtone and re- enter it became it seems it has a minimal time slot its recording on.( Example): Before recording that name, wait a few seconds before you say that name so the blank sound is part of the recording before you state the name you want to enter as the ringtone name.
Thanks but I am using TTS as opposed to talking into the microphone and recording
Hi, I'm wondering if anyone can help me my galaxy note 3 keep asking me for updates randomly I updated several times but still asking me for updates
Do a soft Boot by holding down the On button until our device vibrate then let go and let it restart and see what happens then.
Try "Speak Who Is Calling Ringtone" App from Google Play Store. Note before enabling the app make sure the names in your contacts are all accountable so the app can read the names and SMS that you received.
